Hello all,
I'm trying to use Creo3, instead of Creo2.
I'm starting Creo from my working directory with a batch file (that start parametric.bat).
Confg.pro of both Creo2 and Creo3 are identical.
Within Creo3, I don't have appearances libraries.
And, for example, when I'm going to Render > scene : in Creo2, I have a preview of 10 scenes, in Creo3, list is empty
So, I'm wondering how to correctly configure Creo3 to access to appearances, scenes... libraries.
first of all start Creo 3 without config.pro. This test tells you whether the problem is hidden in Creo 3 installation -OR- inside config.pro file.
MH
MH
