hi..
guys please help me to open the software.
while double clicking on creo icon it is not getting opened.
as per the tutorial of using trail file,which i got from you tube, i changed the directory of trail file through these method
file-->option-->configuration editor-->found trail file-->chosen one directory other than default one-->add/change-->while saving i had given config.pro then saved the editing.
after this i cant open the creo software.i tried to uninstall the same for reinstalling.which is also not not working.
i am using windows 10.
i completely stuck with the problem.can u suggest a solution.????
