I have a brand new computer to run Creo 3.0. It has a crazy 4k hi def video card and a 4k hi def monitor. In order to prevent windows 10 video settings from interfering with my awesome video card, I had to disable display scaling in Creo (see properties, compatability). Problem is the windows setting for the 4k high pixels resolution makes the icons in Creo super small. is there a way to set icon size/resolution in Creo to be independent of what it is set to in windows??
I need the same help. Creo 4 though. Somebody?
Quick access Toolbar Icons/Buttons.
Try to disble display scaling. This is how to do it: How to disable display scaling on High DPI settings (Windows 10 / 8.1; all programs) - YouTube
Let us know if it works
Hello skvarka juraj
I tried this, but came up with same problem.
Small icon/buttons.
Thank You for trying/Help
Doug
Changing resolution is global issue. So you can only change resolution of whole windows. I do not know about any resolution setting in Creo.
