In creo when I create a mapkey which starts a batchfile (eg. to copy a filename), the batch file always flashes on screen. Kind of irritating. Is there a way to get rid of this?
I tried manually modifying the mapkeys in config.pro to go like this: "start /m c:\\.."
In DOS command this works perfect but not in Creo.
Also referring to a minimised .lnk linked to the batch file does not work in Creo (although it works fine in windows explorer).
BP,
I assume Creo Parametric's "open system window" functionality is running the command defined by the environment variable "ComSpec" which is typically C:\windows\system32\cmd.exe. I haven't tested this. It's simply my assumption.
If my assumption is true, try changing the ComSpec variable in the .psf file [or at the System/User environment level].
There are alternatives to the cmd.exe file. A simple search should give multiple results.
Perhaps you can try something along the lines of:
ComSpec=C:\windows\system32\cmd.exe /C start "MinWindow" /WAIT /B /MIN
Keep in mind that many of PTC's programs are started with .bat files. Switching the ComSpec variable may have adverse effects on other functionality in Creo Parametric.
Dan N.
