Anyone know what this is for? set PDM_RETRIEVE_NO_UPDATES=TRUE. It's in another groups loadpoint batch file for Creo.
Hello David,
I saw that you opened a case with PTC TS and the answer seems to be that the option is obsolete.
However, it also seems that the name is slightly different or there is a second option with similar name.
Maybe you can provide a short summary of the solution for the community (if issue has been fully resolved so far)
Gunter
