PTC Requirements Validation & Source 13.4 has Released!
KartikOak
Hello Customers -
PTC Requirements Validation & Source 13.4 has been released and should start showing up on the download location for you to try out and use in the next 48 hours.
Key Highlights
Stronger Authentication with OIDC
  • RV&S Swing/Java Client now supports OIDC-based authentication.
  • Web interface supports OIDC-based authentication.
  • TWX Flow
  • OSLC – DPT with Windchill
Updates in the Swing Interface
  • The attribute column configuration now displays a list of attributes in the context of the Types shown in the View.
  • Show the “Name of Perspective” currently in use and preserve column widths when shared with other users.
  • Wrap Text is now introduced on Item Preview and Item Details relationship table, along with the Text columns in the Relationship View.
  • Export Trace Field details in Word
  • New Report recipe to include Export to Excel, thereby allowing Trace Field details to be exported
  • Substitute Parameters in Word Export
  • Detect modified working files without manual sandbox refresh
SCM Updates
  • Deprecated Throttling – replaced with new simplified configurations
    • Default DTS Configuration: This configuration supports FSA deployments with IM and SI servers at the main site and proxy servers at remote sites.
    • Latency-Based DTS Profiles: Predefined latency-based DTS configuration profiles enhance data transfer throughput for actions like project priming, add member, resync and check-in operations.
    • Optimized Buffer Sizes: Default data transfer buffer sizes have been optimized for better throughput.
  • Improved Client – Server & Client – Proxy connections
    • Critical RMI/API Handling: Special handling of the system internal/high-priority RMI/APIs ensures connectivity between server, proxy, and client during peak usage hours and large data priming.
  • Glass Pane for better user - client interaction.
Platform Updates
  • PTC RV&S updated to JDK 21
Documentation
Download
0 REPLIES 0
