Please provide clarifications about the error code MKS6188819
AM_7069165
What exactly command line option should I use ? Please help. Thank you very much.
The operation could not complete because the working file size exceeds the Server working file size governor.
Use the Add Member From Archive command to re-add the archive, followed by the Check In command with the
Convert Archive to Reference  on Governor option set to check in the working file
We are using Windchill RV&S 13.2.0.3
Pleas see the attached image
Hi @AM_7069165
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
