Not able to add a stream entry when calling the service via REST API, the service result is success but no entries are being added to the respective stream. Tries using both Administrator & Non-Admin user.Works fine when executed from inside thingworx. Please suggest.
Hi @tsharma.
Can you provide your Post request? Are you passing the exact same record each time you test? If so, it may be overwriting.
Regards.
--Sharon
