Animated widget with tooltip
Ilya
8-Gravel
I've upgraded Thingworx from 8.4 to 8.5 and realized that tooltip feature has gone from the most widgets where it was available.
I need a widget which shows different pictures (actually icons) are set dynamically, and dynamic tooltip (a string from some service), which I can format (at least set style).
Before I used ValueDisplay, but it's new implementation does not allow it anymore. Widgets ptcsimage/
ptcsicon don't have tooltip neither.
I've found it only in Gauge, but I don't need a needle.
Could you advise a widget if such exists, or it will be fixed?
Hello @Ilya,
Just in case you don't get a better answer, I suggest to look in the direction of overlaying an Image with some widget which supports tooltips (e.g. a fully transparent button). It's a bad idea, but I guess you're already desperate enough, since you started to look at Gauges...
Constantine
Vilia (my company) | GitHub | LinkedIn
Hello @Ilya,
Constantine
Thank you, Constantine .
You answer was the only, and it works.
@ptc, you want us to think hard when we just upgrade software. Please keep the existing functionality and add new.
