If I create a notification entity in composer, and a trigger, it will put information about this in 2 tables in the DB (notificationcontent_model, notificationdefinition_model). When I delete a trigger, it is not deleting this row from the table. Because of this, I cannot create a new trigger with the same name on the same notification entity. For now, I have been deleting this row in the DB table in order to ensure this name is available for use again. I also noticed the same thing happens if you delete the entire notification entity. None of its data are removed from the tables in the DB.
Is this a bug? Are there any side effects to removing these rows from the table in the DB when a trigger is deleted?
Why not creating a ticket with PTC Support? You are not supposed to delete stuff from the database directly.
I thought I would ask here first. I can create a ticket.
I checked to see if a case was opened for this but couldn't find one. If it was opened under a different account, please let me know so we can track it and post the solution here.
Regards.
--Sharon
