Hi @slangley
Thank you for following up.
To provide more context on the fix:
The issue was occurring while using one of the SCPA Dashboard features, which allows us to create dashboards specific to a particular user/customer. When the customer user logs in and navigates to the assigned dashboard page, the configured dashboard should be displayed.
However, for one specific Group, the dashboard consistently failed with the error:
"Error retrieving dashboard. Contact your administrator on runtime"
Service error:DashboardFunctions → GetDashboard : null
This issue was only happening for that specific Group and not for others.
Deleted the existing dashboard that was created using the SCPA dashboard feature
Recreated a new dashboard from the Dashboard page
Reconfigured it for the same user/customer setup
After recreating the dashboard, the issue was resolved and it started working as expected.
No upgrades were performed
No permission changes were made
No configuration changes were done apart from recreating the dashboard
The root cause is still unknown
It appears that the original dashboard may have had some internal corruption or invalid runtime data, but this is only an assumption.
If anyone has insight into what could cause this behavior in the SCPA dashboard configuration, I would be interested in understanding the underlying reason.
Regards.
Article - "Dashboard shows error "Error retrieving dashboard. Contact your administrator" when logging in with a non-administrative user in ThingWorx": https://www.ptc.com/en/support/article/CS239006
Hi Vladimir,
Thank you for your response.
I have reviewed the Article and Dashboard functions, and both Visibility and Run Time permissions are correctly assigned to the Administrator group. My user account is also part of the Administrator group.
I do not encounter any issues when executing the same function for other groups. However, for one specific group, I am receiving a null error.
I have tried creating new dashboard and the issue got fixed.
For the sake of our members, can you provide more detail regarding the fix? Did you upgrade any components? Did you do anything differently in your second attempt?
Regards.
--Sharon
Hi @slangley
Regards.
Thank you for sharing that detailed information! Please feel free to mark your last reply as the Accepted Solution for the benefit of others in the community.
Regards.
--Sharon
