Function to update stream entries
a-dub
3-Newcomer
All..
I have a stream with data coming in. I'd like to create or use a service to update stream entries.
End goal would be for the service to have 3 inputs (start,end,tag) so the service would add the "tag" tag to all entries between "start" datetime and "end" datetime.
I see the built in "UpdateStreamEntry" so I suppose I could query all stream entries between the two datetimes, and then loop through that entire query result calling UpdateStreamEntry each time.
However, I'd like to know if there is already a pre-built function to do this?
You have the service QueryStreamEntriesWithData in order to query the data, and then you can iterate over each previous result and use UpdateStreamEntry
a-dub
3-Newcomer
(To:CarlesColl)
Here is some code I developed for this task (if anyone wants to re-use). You can replace GetStreamEntriesWithData service with QueryStreamEntriesWithData to use like CarlesColl said.
var table =  me.GetStreamEntriesWithData({
	oldestFirst: true /* BOOLEAN */,
	maxItems: 15 /* NUMBER */
var row;
var tableLength = table.rows.length;
for (var x=0; x < tableLength; x++) {
    row = table.rows[x];
    row.tags.AddTag("BatchNumbers","D000001");
    me.UpdateStreamEntry({
		values: me.CreateValuesWithData({
        	values: {column1: row.column1,
                        column2:  row.column2,
                        column3:  row.column3,
                        column4:  row.column4,
                        column5:  row.column5,
                        column6:  row.column6,
                        column7:  row.column7} /* JSON */
                    }) /* INFOTABLE */,
		streamEntryId: row.id /* STRING */,
		source: row.source /* STRING */,
		tags: row.tags /* TAGS */
var result =  me.GetStreamEntriesWithData({
	oldestFirst: true/* BOOLEAN */,
	maxItems: 20 /* NUMBER */
