How can I Fetch specific property data from QueryPropertyHistory and show in a line chart graph.
Pratik_Aswale
11-Garnet
I want to fetch a specific property data from QueryPropertyHistory service.
consider like I have a thing and have a humidity and Temperature property. So I want to only fetch Temperature property data from QueryPropertyHistory. How can we do that?
Thanks.
Hi @Pratik_Aswale
In Select Entity you can select your Thing Name
Select Service QueryNamedPropertyHistory service in service category
After that, pass your thing name to EntityName
/VR
Hi @Pratik_Aswale
You can use QueryNamedPropertyHistory service to get specific property value from Value Stream
/VR
Hi @Velkumar
Thanks for the response...
 yes its works.
But In my use case I have 3 different Things which has some property data I log and store in valuestream .Now In mashup I have dropdown widget and line chart widget.
How can we get data after selection from dropdown 1 thing and data will shown in linechart of that 1 thing?
Hi @Pratik_Aswale
Pass Thing Name from Drop down to service dynamically. It should work.
Pass thing name from drop down
/VR
Hi @Velkumar
Which service to pass dropdown widget so that I can get thingname and also which selected Entity should I enter in below so that I can get QueryPropertyHistory service data and bind All data to line chart?
Hi @Pratik_Aswale
/VR
