How do I overwrite any widgets over the other?
gprasad-21
1-Visitor
I have a case where i need to put a widget over another. That is I need to put a shape above Map. So please do advice me how can I do that?
supandey
(To:gprasad-21)
Hi Guru, could you please add some more description to your use case what sort of shape exactly are you referring to? Is that shape also a widget? If yes what type of widget is it? Do let us know of your ThingWorx version too.
Hi. I am using ThingWorx Composer 7.3.2. Shape is a widget where we could give shapes. I used a widget named map and above that tried to give another widget named shape and the widget I used not being used. So please do check. The shape is a widget, where shapes like square, rectangle, circle,etc can be drawn. But I couldn't put a widget above another widget (i.e, Dragging from the widget box). So please do look this problem and do give me a solution.
V. Guru
In order to place one widget over another you should set z-index property
