How does the thing property sync with kepware ?
seanccc
17-Peridot
#1.  Updating a remote bound property writes its property value to data tag of Kepware
#2.  Updating the data tag writes value to the bound property
Will the  #2 trigger #1  one more time ?
for exmaple :  DataTagA  get changed  causing  PropertyA get changed ,  and  this changes on PropertyA  send to kepare and change the DataTagA again,  will it happen ?
Sean
Hello @seanccc ,
Could you pls clarify more about the use case?
Does your query implies if DataTagA changes in kepware and you change PropertyA on ThingWorx and than again vice versa?
Kindly elaborate in detail.
Bhawna
Hi  Bhawna,
For the  DataTagA and PropertyA  ,  changes on either side will update the other side.  Here is the case :
Time       Action
t1             DataTagA changed
t2            PropertyA changed  because DataTagA changed
t3            will DataTagA get changed  again because PropertyA changed at t2  ?
slangley
(To:seanccc)
Hi @seanccc.
Updates received into ThingWorx from Kepware should not trigger a looping effect.
Here's an article that provides details of the options for updating the property values, though it doesn't address your question specifically.
What version of ThingWorx are you running?  Are you running into issues?  Any errors in the logs?
Regards.
--Sharon
