How to Use Filter chart Based on the dropdown Values
LY_10691079
Hi Everyone,
I have a requirement in which I ahve data like this
Now i want to sort data Based on Approved state , Sports Category
Mainly Approved State and then want to show the data on line or bar chart
so Basically requirement is in the drop down all the approved state will be there and when I select one of the approved state the data will populate in the Bar/ Line chart
so how can I implement this pls share your solution
Lav
Hi @Surya_Tiwari ,
I looked into this article but seems it is having a query as an input parameter but in my case I have an SQL query which is fetching data from DB so I am not sure how can I use this query as an input parameter to my SQL query so if you can guide here then it will be helpful and also like after querying this data how can I pass this to line/bar chart please share the solution if possible
Thanks in Advance
Lav
Hi @LY_10838955
Can you share the entity here or is it better for you to create an SF case with the PTC support team, we will look it over.
