How to add Custom Button in Grid Widget
ParthBhadiyadra
Hello
I want to remove Display and Reset button and add new button at right side/ replace reset button with add button, how can I do this
In below image I want to replace reset button and hide display drop down
In a quite recent release PTC added the possibility to add custom buttons to the grid widget.
So if you are on a very recent release of Thingworx you should be able to follow above link for what you want to do.
Jens
Jens
Hello @jensc
Thank you for your reply
I am using the Thingworx 9.3.7 Version there is no support this way so there is any other way to achieve this.
I suppose you could move the buttons if you use a static mashup so that they "appear" to be a part of the grid widget.
But I wouldn't say that it is a good option.
Jens
