How to change ReadOnly to a binding target
hails.alex91@gm
7-Bedrock
I am trying to adjust the TW textbox widget so that its ReadOnly property can be a binding target. I want some logic to be evaluated, and that evaluation will determine if it is ReadOnly.
I have adjusted the properties and such so that in the IDE it can have a variable bind to its ReadOnly property.
However, when i go to the Runtime screen, the textbox's ReadOnly property does not seem to update.
I am new to Thingworx and am trying to wade through the OOTB components and documentation to figure this out, but I am stuck. Here is my runtime code...do I need to adjust something in my Runtime or my IDE to make this happen?
Runtime:
TW.Runtime.Widgets.textbox_hails = function () {
        var thisWidget = this;
        var defaultValue = undefined;
        var onInputChange = function () {
            thisWidget.setProperty('Text', thisWidget.jqElement.find('input').val());
        // fire my bindable event so listeners know something happened
        thisWidget.jqElement.triggerHandler('Changed');
        this.runtimeProperties = function () {
            return {
                'needsError': true
        this.renderHtml = function () {
            defaultValue = thisWidget.getProperty('Text');
            var formatResult = TW.getStyleFromStyleDefinition(thisWidget.getProperty('Style', 'DefaultTextBoxStyle'));
  var border = TW.getStyleCssBorderFromStyle(formatResult);
            var textSizeClass = 'textsize-normal ';
            var textAlignClass = thisWidget.getProperty('TextAlign');
            if (thisWidget.getProperty('Style') !== undefined) {
                textSizeClass = TW.getTextSizeClassName(formatResult.textSize);
            var cssInfo = TW.getStyleCssTextualFromStyle(formatResult);
            var cssTextBoxText = TW.getStyleCssTextualNoBackgroundFromStyle(formatResult);
            var inputType = 'text';
            if (this.getProperty('MaskInputCharacters') === true) {
                inputType = 'password';
            var placeholderText = thisWidget.getProperty('PlaceholderText');
            var html = '<div class="widget-content widget-textbox"><table ' + (thisWidget.getProperty('InnerShadow') === false ? '' : 'class="shadow" ') + ' border="0" cellpadding="0" cellspacing="0" height="100%" width="100%" style="' + cssInfo + '"><tr><td valign="middle"><input type="' + inputType + '" class="widget-textbox-box ' + textSizeClass + ' ' + textAlignClass + '" tabindex="' + thisWidget.getProperty('TabSequence') + '" style="' + cssTextBoxText + '" ' + (thisWidget.getProperty('ReadOnly') === true ? 'disabled="disabled" ' : '') + ' value="' + (thisWidget.getProperty('Text') === undefined ? '' : thisWidget.getProperty('Text').replace(/"/g, "&quot;")) + '" placeholder="' + (placeholderText === undefined ? '' : placeholderText) + '"></input></td></tr></table></div>';
            return html;
        this.afterRender = function () {
            // notice when "text" changes and update the 'Text' property
            var TextboxLabelStyle = TW.getStyleFromStyleDefinition(thisWidget.getProperty('TextboxLabelStyle', 'DefaultWidgetLabelStyle'));
            var textboxFocusStyle = TW.getStyleFromStyleDefinition(thisWidget.getProperty('DefaultTextboxFocusStyle', 'DefaultFocusStyle'));
            var TextboxLabel = TW.getStyleCssTextualNoBackgroundFromStyle(TextboxLabelStyle);
            var TextboxLabelSize = TW.getTextSize(TextboxLabelStyle.textSize);
            var TextboxLabelAlignment = this.getProperty('LabelAlignment', 'left');
            var cssTextboxFocusBorder = TW.getStyleCssBorderFromStyle(textboxFocusStyle);
            var TextboxHeight = thisWidget.getProperty('Height');
            if (thisWidget.getProperty('TextboxLabelStyle', 'DefaultWidgetLabelStyle') === 'DefaultWidgetLabelStyle'
                && thisWidget.getProperty('DefaultTextboxFocusStyle', 'DefaultFocusStyle') === 'DefaultFocusStyle') {
                if (!addedDefaultStyles) {
                    addedDefaultStyles = true;
                    var defaultStyles = ' .runtime-widget-label { ' + TextboxLabel + TextboxLabelSize + ' text-align: ' + TextboxLabelAlignment + '; }' +
                        ' .widget-textbox table { ' + border + ' }' +
                        ' .widget-textbox.focus table { ' + cssTextboxFocusBorder + ' }' +
                        ' .widget-textbox-box { height: ' + TextboxHeight + 'px; }';
                    $.rule(defaultStyles).appendTo(TW.Runtime.globalWidgetStyleEl);
            } else {
                var styleBlock =
                    '<style>' +
  '#' + thisWidget.jqElementId + ' { ' + TextboxLabel + ' }' +
                        '#' + thisWidget.jqElementId + '-bounding-box .runtime-widget-label { ' + TextboxLabel + TextboxLabelSize + ' text-align: ' + TextboxLabelAlignment + '; }' +
                        '#' + thisWidget.jqElementId + ' table { ' + border + ' }' +
                        '#' + thisWidget.jqElementId + '.focus table { ' + cssTextboxFocusBorder + ' }' +
                    '</style>';
                $(styleBlock).prependTo(thisWidget.jqElement);
            var textboxSelector = '#' + thisWidget.jqElementId + ' .widget-textbox-box';
            var textboxContainer = '#' + thisWidget.jqElementId + '.widget-textbox';
            $(textboxSelector).on('focus', function () {
                $(textboxContainer).addClass('focus');
        var inBlurHandlingInIe8 = false;
            $(textboxSelector).on('blur', function (e) {
                $(textboxContainer).removeClass('focus');
                try {
                    if (e.target.selectionStart !== undefined) {
                        thisWidget.setProperty('CursorPosition', e.target.selectionStart);
                    } else {
                        // ie8
                        if( inBlurHandlingInIe8 ) {
                            return;
                        inBlurHandlingInIe8 = true;
                        e.target.focus();
                        var el = e.target;
                        var range = document.selection.createRange();
                        if (range && range.parentElement() == el) {
                            var len = el.value.length;
                            var normalizedValue = el.value.replace(/\r\n/g, "\n");
                            // Create a working TextRange that lives only in the input
                            var textInputRange = el.createTextRange();
                            textInputRange.moveToBookmark(range.getBookmark());
                            // Check if the start and end of the selection are at the very end
                            // of the input, since moveStart/moveEnd doesn't return what we want
                            // in those cases
                            var endRange = el.createTextRange();
                            endRange.collapse(false);
                            var start, end;
                            if (textInputRange.compareEndPoints("StartToEnd", endRange) > -1) {
                                start = end = len;
                            } else {
                                start = -textInputRange.moveStart("character", -len);
                                start += normalizedValue.slice(0, start).split("\n").length - 1;
                                if (textInputRange.compareEndPoints("EndToEnd", endRange) > -1) {
                                    end = len;
                                } else {
                                    end = -textInputRange.moveEnd("character", -len);
                                    end += normalizedValue.slice(0, end).split("\n").length - 1;
                            thisWidget.setProperty('CursorPosition', start);
                        e.target.blur();
                        setTimeout(function() {
                            // keep ie8 from infinite loop
                        },1);
                } catch(err) {
                    TW.log.error('error trying to get cursor position on blur',err);
            thisWidget.jqElement.find('input').bind('change', onInputChange);
        this.updateProperty = function (updatePropertyInfo) {
            console.log(updatePropertyInfo.TargetProperty);
            console.log(typeof updatePropertyInfo.SinglePropertyValue);
            console.log(thisWidget.jqElement.find('input').val(updatePropertyInfo.SinglePropertyValue));
            if (updatePropertyInfo.TargetProperty === 'Text') {
                thisWidget.jqElement.find('input').val(updatePropertyInfo.SinglePropertyValue);
                thisWidget.setProperty('Text', updatePropertyInfo.SinglePropertyValue);
            if (updatePropertyInfo.TargetProperty === 'ReadOnly') {
                thisWidget.setProperty('ReadOnly', updatePropertyInfo.SinglePropertyValue);
        this.resetInputToDefault = function () {
            thisWidget.jqElement.find('input').val(defaultValue === undefined ? '' : defaultValue);
            thisWidget.setProperty('Text', defaultValue);
        this.getProperty_Text = function () {
            if (thisWidget.jqElement !== undefined) {
                return thisWidget.jqElement.find('input').val();
            } else {
                return this.properties['Text'];
        this.beforeDestroy = function () {
            thisWidget.jqElement.find('input').unbind();
IDE:
TW.IDE.Widgets.textbox_hails = function () {
    this.widgetProperties = function () {
        return {
            'name': 'Textbox_Hails',
            'description': 'Enables the user to enter text',
            'category': ['Common'],
            'defaultBindingTargetProperty': 'ReadOnly',
            'supportsLabel': true,
            'supportsResetInputToDefault': true,
            'properties': {
                'Text': {
                    'isBindingTarget': true,
                    'isBindingSource': true,
                    'defaultValue': '',
                    'baseType': 'STRING',
                    'warnIfNotBoundAsSource': false
                'Width': {
                    'defaultValue': 200
                'Height': {
                    'defaultValue': 24,
                    'isEditable': true
                'TextAlign': {
                    'defaultValue': 'left',
                    'description': 'The positioning of the text.',
                    'selectOptions': [
   { value: 'left', text: 'Left' },
                                 { value: 'right', text: 'Right' },
                                 { value: 'center', text: 'Center' }
                'LabelAlignment': {
                    'selectOptions': [
                'PlaceholderText': {
                    'defaultValue': '',
                    'description': 'Textbox placeholder text. Not supported in IE9 and earlier versions.'
                'ReadOnly': {
                    'description': 'Is the textbox read only',
                    'baseType': 'BOOLEAN',
                    'defaultValue': false,
                'MaskInputCharacters': {
                    'description': 'Do not show contents of entry at runtime',
                'TabSequence': {
                    'description': 'Tab sequence index',
                    'baseType': 'NUMBER',
                    'defaultValue': 0
  'InnerShadow': {
                    'description': 'Adds inner shadow effect to the inside of the textbox',
                    'defaultValue': true
                'CursorPosition': {
                    'defaultValue': 0,
                'Style': {
                    'baseType': 'STYLEDEFINITION',
  'defaultValue' : 'DefaultTextBoxStyle'
  'TextboxLabelStyle': {
  'defaultValue': 'DefaultWidgetLabelStyle'
  'DefaultTextboxFocusStyle': {
  'defaultValue': 'DefaultFocusStyle'
                'Editable':{
                    'baseType':'BOOLEAN',
                    'defaultValue':true
        var formatResult = TW.getStyleFromStyleDefinition(this.getProperty('Style'));
        var textSizeClass = 'textsize-normal';
  var textAlignClass = this.getProperty('TextAlign');
        if (this.getProperty('Style') !== undefined) {
  var TextboxStyleBorder = TW.getStyleCssBorderFromStyle(formatResult);
        var html = '';
        html += '<div class="widget-content widget-textbox '+ textAlignClass +'"><div class="widget-textbox-wrapper" style="' + TextboxStyleBorder + '"><span class="widget-textbox-text-icon"></span><table ' + (thisWidget.getProperty('InnerShadow') === false ? '' : 'class="shadow"') + ' border="0" cellpadding="0" cellspacing="0" height="100%" width="100%" style="'+ cssInfo +'"><tr><td valign="middle"><span class="widget-textbox-text ' + textSizeClass + '" style="' + cssTextBoxText +'">' + ((this.getProperty('Text') === undefined) ? 'Textbox' : Encoder.htmlEncode(this.getProperty('Text'))) + '</span></td></tr></table></div></div>';
        return html;
        //TW.log.info('valuedisplay this.afterRender');
  var TextboxLabelStyle = TW.getStyleFromStyleDefinition(thisWidget.getProperty('TextboxLabelStyle'));
  var TextboxHeight = this.getProperty('Height');
  var resource = TW.IDE.getMashupResource();
  var widgetStyles = '#' + thisWidget.jqElementId + '-bounding-box .builder-widget-label { '+ TextboxLabel + TextboxLabelSize + ' text-align: ' + TextboxLabelAlignment + '; }' +
            '#' + thisWidget.jqElementId + ' .widget-textbox-wrapper { height: ' + TextboxHeight + 'px; }';
  resource.styles.append(widgetStyles);
    this.widgetEvents = function () {
        return {
            'Changed': {}
    this.afterSetProperty = function (name, value) {
        var result = false;
        switch (name) {
            case 'Style':
  case 'TextAlign':
  case 'TextboxLabelStyle':
            case 'InnerShadow':
            case 'LabelAlignment':
                result = true;
                break;
            case 'Text':
                thisWidget.jqElement.find('.widget-textbox-text').text(value);
                break;
            default:
                break;
        return result;
    this.validate = function () {
        var result = [];
        var isReadOnly = this.getProperty('ReadOnly');
        if( isReadOnly !== true )  {
            if (!this.isPropertyBoundAsSource('Text')) {
                result.push({ severity: 'warning', message: '{target-id}: Text is not bound to any target.  If you check ReadOnly you will not receive this warning.' });
        return result;
Not sure if you have access to the actual Thingworx instance, but I always recommend just looking at an existing Widget that has an example of a bindable property.
you can get to the widget code by going to Tomcat folder/webapps/Thingworx/common/thingworx/widgets
Hi Pai...I do have access to the Thingworx instance, and I have been tirelessly looking through all of the JS files. I know how to make a property bindable...that has been completed in the code above.
Here is an example of what is happening and what my main question is:
1. ReadOnly is bindable property
2. The 'Output' of an expression (output value type is Boolean, and the expression is 1>2) is mapped to ReadOnly
3. I have added in some Logs, and they verify that the UpdatePropertyInfo.TargetProperty is ReadOnly when i press the button to evaluate
4. UpdatePropertyInfo.TargetProperty.SinglePropertyValue, however, is being logged as string instead of boolean
5. When I log the value of ReadOnly to the console after the update, it returns false (this is correct)
6. The textbox is not re-rendered as a ReadOnly textbox
I do not know how to re-render the page using the properties that have since been updated. Is this something that needs to be defined in an Event Trigger? Is there a call that i need to make to re-render? Does logic need to be specified in my afterRender() function?
The TW widgets have logic written into their renderHTML() functions that puts in the disabled:disabled style attribute, but I am not able to figure out how it handles dynamic properties (isVisible).
I have been facing the same issue for over a week now and would appreciate as specific of an answer as possible. My team has faith in this products ability, but a lack of support and/or guidance on how to make the simple changes we need will render this product useless.
Thank you in advance for your help!
I've found a much easier solution is to have two widgets, one being disabled/read-only; and then overlap the two widgets and bind the 'Visible' state of each.
Before Buttons had bindable 'Disabled' state, I had a normal button and a hidden button styled to look disabled, both in the same position; then on whatever condition, I'd hide the working button and reveal the 'disabled' button.
