How to get the fields definition of an InfoTable
pruby
8-Gravel
Is it possible to get the field definition of an InfoTable prior to knowing its DataShape?
I am currently doing it by converting my InfoTable to json and then by taking the dataShape definition:
var fields = Resources["InfoTableFunctions"].ToJSON(params);
var result = fields.dataShape.fieldDefinitions;
This works fine but I'm wondering if there is a nicer way to do this, by using services like getDataShape and GetFieldDefinitions.
The correct way of recovering the Fields of an Infotable with and unknown DataShape it's this one:
var iLF ;
if ((myInfotable.dataShape==null)||(myInfotable.dataShape==undefined)) {
   iLF = myInfotable.ToJSON().dataShape.fieldDefinitions;
 } else {
   iLF = myInfotable.dataShape.fields;
for (var key in iLF) {
 logger.info("Field Name "+key+" baseType: "+iLF[key].baseType);
PaiChung
22-Sapphire I
(To:pruby)
There was a similar thread to this before.
I think you can just do something like
for each (var field in myinfotable.fields)
var iLF ;
 } else {
Ascherer17
(To:CarlesColl)
This is very helpful!  Thank you.
Leigh
Emeritus
(To:pruby)
Hi @pruby
Did Carles reply solve your issue? If so, please mark this as an Accepted Solution for the benefit of the rest of our Community. If not, let us know the current situation.
Thanks!
Leigh
