How to use ExtractZipArchive?
Rishabh345
Hi All!
I'm currently using Thingworx 8.5.19 version.
The intent is to programmatically (using Thingworx service), unzip a file containing many JSON files, so that we can process the content in the JSON.
Getting below error:
Unable to Invoke Service ExtractZipArchive on SBR.OEMFeed.RawData.Repo : Cannot extract file "Atlas Copco_RawFeed.zip" to target directory "Atlas Copco".
Any lead can be helpful.
jensc
17-Peridot
(To:Rishabh345)
What does your unzip service look like?
This is one I am using to extract source control files;
let result = Things["SystemRepository"].ExtractZipArchive({
	path: '/RJP_Extracted/' /* STRING */,
	zipFileName: '/RJP_Import/20230110.zip' /* STRING */
Where "path" is where you will extract your files and "zipFileName" is the path to where your zip file is.
I have a brief memory that I have also had the same error and it was because the path was not correct.
Jens
jensc
17-Peridot
(To:Rishabh345)
Jens
