Information about 'GetEntityList' service
amittal-3
I m trying to use the 'GetEntityList' service in Thingworx which can be found in 'EntityServices' resource. This service has couple of parameters as below:
// result: INFOTABLE dataShape: "RootEntityList"
var result =  Resources["EntityServices"].GetEntityList({
	maxItems: undefined /* NUMBER */,
	nameMask: "PART" /* STRING */,
	type: "Thing" /* STRING */,
	tags: "CMU_MT_IOTServer2.0:AUTO" /* TAGS */
I am not able to understand about 'nameMask'. How is this parameter used? Does it take Reg-Ex as input or does it work on 'contains' mechanism? Kindly share some information/samples/examples on how to use this parameter.
Thanks in advance.
-Aditya Mittal
khayes1
(To:amittal-3)
Hi yes it is like reg-ex, so you could use filters such as:
"*PART*"   which would return anything that contains 'PART' in the name
or
"PART*"   which would return anything that begins with 'PART' in the name
or
"*PART"   which would return anything that ends with 'PART' in the name
so to get all Thing entities with 'PART' somewhere in the name you can use
var params = {
nameMask: "*PART*" /* STRING */,
tags: "myTag" /* TAGS  if required*/
// result: INFOTABLE dataShape: RootEntityList
var result = Resources["EntityServices"].GetEntityList(params);
khayes1
(To:amittal-3)
or
or
var params = {
Just to epand on @khayes1 answer:
  1. You can also use "?", which stands for a single character (analog of "." in regex)
  2. It looks like you can also use regex character classes and quantifiers, e.g. "Device-[0-9]{4}" to find "Device-0001", etc.
/ Constantine
Vilia (my company) | GitHub | LinkedIn
amittal-3
(To:Constantine)
Thanks Guys for the quick response
Aditya
