Proportional Chart
keriw
Proportional Chart
I'm trying to use the proportional chart, with dates on the x-axis and hours on the Y-axis.  When I run it, the date is not showing below (says invalid date), and the hours data is showing all in one column.  Any thoughts on why this would be happening?
posipova
20-Turquoise
(To:keriw)
Please make sure your mappings are correct. For the Invalid Number issue, check your datashape field definitions and make sure the datetime property has a base type of "datetime". In your widget mapping,
    • XAxisLabelType set to "Date/Time"
For the data showing all in one column, again make sure to map properly your data and datafield.
  • XAxisField has to have your datetime field selected.
keriw
(To:keriw)
It appears that you can't actually define the X-axis on a proportional chart.  I had everything configured correctly.  I ended up using the label chart instead and having to do a stacked series, which involved me having to pivot my table first.
Keri
