[Request] Time Series DataSet.
Mouad_Ech-chaab
7-Bedrock
Hi everyone,
do anyone of you have a time series data set that i can use to try time series prediction using thing predictor ?
Regards.
Hi
You can find a sample time series dataset to use with Analytics at https://www.ptc.com/en/support/article?n=CS258345
However, for ThingPredictor, please be mindful of the limitation noted in Help Center: https://support.ptc.com/help/thingworx_hc/thingworx_analytics_8/#page/thingworx_analytics_8%2Fthingpredictor%2Fthingpredictor-limitations.html%23
"In this release, the ThingPredictor client scoring through Analytics Manager does not support time series models"
Release 8.3 should bring better support for time series with ThingPredictor
Hi Christophe,
Thank you for the provided data set , but the question is what is the goal variable in that  data set ?
Hi
The goal is WaterVolume
Christophe
Thank you , what i want is to predict time  before  failure for example ,  how i can do use the dataset you provided to do that ?
Hi
The dataset is a sample dummy time series dataset.
It pretends to predict the watervolume based on some current and voltage values.
It is not about failure prediction.
I do not have dataset for time to failure
Christophe
