Hello all,
I use Schedule chart and I want to find a way how to expand/collapse several or all groups at the same time.
Now, by default, it is possible to expand only one group (if I click on another group, the first one collapses).
For example, if I click on LABEL-1 group, the detail opens, but if I click on LABEL-2 group, the detail opens for LABEL-2 group (while the detail for LABEL-1 group collapses). Please, find screenshots
Is it possible to expand/collapse all or several groups at the same time?
Hi @olga_s
I'm not sure there is a way to do this without a custom solution, but if you can provide your entities, I'm happy to play around with it.
Regards.
--Sharon
Hi @slangley ,
Thanks for your reply!
I used schedule chart and data for it from a default 'Theme Preview' mashup as an example. For convenience, I've copied it into a separate project. Please, find attached entities
Hi @olga_s
I tested under ThingWorx 10.0.1 but couldn't find a way to do this. I suspect you will need to come up with a custom solution to solve the issue; however, I have engaged with a colleague who is going to spend more time on it to see if he can come up with something.
I'll let you know more following the migration to the new community in a couple of weeks.
Regards.
--Sharon
