ThingWorx Package Creation as extension takes very long even for small projects
MA8731174
16-Pearl
Hi everyone,
I have a question regarding the Publish Solution process as extension in ThingWorx.
Even for very small projects — for example, a project containing only 3 entities — the publishing process (as Extension) takes quite a long time before the download starts. I have also tested it by calling the “Publish Solution” REST API directly, but the result is the same — it takes noticeably long to generate the package.
We are currently using ThingWorx 9.3, and I was wondering:
  • Is this expected behavior for this version?
  • Has the performance improved in newer ThingWorx releases?
  • Or is there maybe any configuration or optimization that could speed this up?
This is just for my understanding — but any technical explanation about what happens during the publish process would be great.
Thanks in advance!
Hi @MA8731174,
Are you talking about Package and Publish Your Solution to Solution Central?
I think this is a support case issue that requires case-by-case investigation. Please consider opening a support case for this issue.
Best,
Tony
