Thingworx Analytics: Issue with Installation of UploadThing
mdeshpande-2
I am setting up Thingworx Analytics 52.2. I followed the installation guides, but I am facing issues with the last step: Installation of UploadThing
  • The UploadThing installs properly.
  • When I verify the isConnected property from the thingworx composer, it seems to be false all the time.
  • I checked on PTC technical support and followed the mentioned steps as well. But it still doesn't work.
I am using thingworx on port 8081 with SSL. I have attached the uploadthing.log file  and the UploadThing.properties file for reference.
I would appreciate any help regarding the same.
Thanks & Regards,
Madhumita Deshpande
jgreiner
(To:mdeshpande-2)
Hi Madhumita,
I found this KCS article that I believe solves the issue you are encountering.
Let me know if this solves the error that you are encountering.
John
Hi John,
I followed the steps in the article,but it is still not working.
Is there any other solution? Is the problem related to SSL(I'm using Thingworx with SSL)?
I would appreciate any help.
Thanks & Regards,
Madhumita
jgreiner
(To:mdeshpande-2)
Hi Madhumita,
I will reach out to the R&D team to see if using ThingWorx with SSL is causing the issue.
Let me know if you have any further questions or concerns.
John
jgreiner
(To:mdeshpande-2)
Hi Madhumita,
I have sent an email to the address that I believe is yours.  Please respond to it if you did get it or let me know through here if you did not.
John
