I cleared Thingworx Extension and restarted Tomcat, but Thingworx doesn't work. Restarting Tomcat and accessing the Thingworx address on the web will recreate the Extension that you deleted from C:\ThingworxStorage\extensions. Can you fix the problem?
Unfortunately, the problem could not be resolved immediately, so we proceeded with reinstalling windows and reinstalling Thingworx. Thank you for your reply.
Hi @MK_10538841 ,
Can you share the Application LOGS when you are restarting Thingworx?
