I'm trying to do a File transfer via Java SDK from my Client to the Thingworx Storage (on Thingworx Server). Herefore I created the following Code using the CopyService:
public static void main(String[] args) {
ClientConfigurator config = new ClientConfigurator();
String uri = "http://xxx.xx.xx.xx:8080/Thingworx/WS";
config.setUri(uri);
config.setAppKey("xxxxx");
config.ignoreSSLErrors(true);try {
ConnectedThingClient client = new ConnectedThingClient(config);FileTransferVirtualThing myThing = new FileTransferVirtualThing("RT1", "File Transfer Example", client);
myThing.addVirtualDirectory("in", "C:\\tmp\\in");
myThing.addVirtualDirectory("out", "C:\\tmp\\out");client.bindThing(myThing);
client.start();ValueCollection parameters = new ValueCollection();
parameters.setValue("sourceRepo", new StringPrimitive("RT1"));
parameters.setValue("sourcePath", new StringPrimitive("/out"));
parameters.setValue("sourceFile", new StringPrimitive("a.txt"));
parameters.setValue("targetRepo", new StringPrimitive("SystemRepository"));
parameters.setValue("targetPath", new StringPrimitive("/files"));
parameters.setValue("targetFile", new StringPrimitive("a.txt"));
parameters.setValue("async", new BooleanPrimitive(false));client.invokeService(ThingworxEntityTypes.Subsystems, "FileTransferSubsystem", "Copy", parameters, 120);
client.shutdown();
} catch (Exception e) {
e.printStackTrace();
The file is not transferred, the error message in the output is the following:
23:58:21.149 [NettyClient-NIO-1] DEBUG c.t.c.c.e.DispatchingClientEndpoint - API REQUEST received [endpoint id: 0] APIRequestMessage [requestId: 2206, endpointId: -1, sessionId: -1, method: POST, entityName: RT1, characteristic: Unknown, target: ]
23:58:21.150 [ClientProcessor-3] WARN c.t.c.c.t.f.FileTransferVirtualThing - File transfer has been canceled. tid: , reason: Unable to Create File [/files/a.txt.SystemRepository.part]
How to deal with this error? Seems like the RT1 Thingworx Thing can't write to this path? What can I do to allow it to write here?
Maybe important to know: Vice versa its working, I can transfer files from /files SystemRepository to my client directory (here I'm getting a Timeout Exception but the File is at least transferred...)
Many thanks in advance!
Are you sure the App Key you are using to connect to the Platform has permission to modify and call services on the file repository?
Just found out the Thingworx Installation had no right to write to the specified Reposity Path. Fixed this privileges issue, now the File gets transferred.
BUT for each File Transfer a "Timed Out Api Request Message" gets thrown (but the file gets transferred). Anyone has an idea how to fix this?
// Should I outsource this question to separate Thread?
