Upgrade Thingworx license 7.4 to 8.4
clansdale
I have a server running Thingworx 7.4 and I would like to migrate to a new server that runs 8.4. Do I need a separate license to do this? Or can I transfer the old license when I move the data.
Thank you
Connor
Yes you need a new license.
The 7.4 uses a default license that comes along with the installation package, while after 8.1, all TWX license are retrieved online.
After you installed TWX 8.4, you will get a licenserequest file in the ThingWorx Platform folder, you will find your device ID in it, go to article for details.
https://www.ptc.com/en/support/article?n=CS271439&posno=1&q=licensing%20thingworx&source=search
clansdale
(To:zyuan1)
Okay, thank you for the reply. When I receive the license file in the new instance, how do I go about removing the old license (from the instance running 7.4)? I don't want to be using two licenses at the same time.
slangley
(To:clansdale)
Hi @clansdale.
No need to remove the license from 7.4.  I assume at some point you'll be decommissioning that instance, correct?
Regards.
--Sharon
clansdale
(To:slangley)
Yes, as soon as I get the new instance up and running.
slangley
(To:slangley)
Hi @clansdale.
There's nothing you have to worry about removing  when it comes to the license.  I would recommend, however, that you retain the original instance for long enough to validate that everything is working as expected on the upgraded instance.
Regards.
-Sharon
