What's the difference between Project and ModelTag ?
seanccc
17-Peridot
Since the Project entity doesn't play the role of namespace,    I don't see any difference for Project comparing with ModelTag.   It seems that the Project entity is just a mandatory ModelTag.
Is there anything I missed in my understanding for the meaning of Project entity ?
Sean
VladimirRosu
(To:seanccc)
Cheers Sean,
Technically speaking, you can imagine indeed that the Project is just a mandatory Model Tag.
The Project attribute itself is simpler than a model tag, being just a simple string (it does not belong to a Vocabulary like the Model Tag).
I tend to think of the Projects like being 1:1 equivalents of applications. For example, all my GitBackup entities belong to the GitBackup Project.
Model Tags are useful to separate inside a project different functionalities (imagine you want to implement SearchV2, you'd create a new Model Tag with this name and apply it to the required entities for that new capability, whether new or existing ones you upgraded).
In Composer, there are a bunch of features related to Projects (Project View, which emulates Eclipse's Package Explorer), then Open Projects (showing open entities per Project),
Also, if you access a Project entity you also gain the capability to package all Entities that belong to that project as an extension (and later, when you connect your ThingWorx instance to Solution Central, to publish your application there).
VladimirRosu
(To:seanccc)
Cheers Sean,
@VladimirRosu ,
Thank you for your elaborate explanation.  It's clear and really helpful.
