can someone point me to a sample python script that sets thingworx properties (through Rest API?)
bwalke
I am a thingworx starter and looking for some reference material on how to use python to communicate with thingworx server to get me started.
adam11
7-Bedrock
(To:bwalke)
Hi Bhaskar,
The Requests HTTP library for Python makes interacting with the ThingWorx API a breeze. The following sample code uses this library to set two Properties (stringProperty and numberProperty) defined on a Thing:
import requests
import json
url = 'https://localhost/Thingworx'
headers = { 'Content-Type': 'application/json', 'appKey': 'ed18a4a1-c6d5-46b3-ace8-b55d148e2384' }
payload = { 'stringProperty': 'ThingWorx', 'numberProperty': 14.3 }
response = requests.put(url + '/Things/ExampleThing/Properties/*', headers=headers, json=payload, verify=False)
Since Tomcat is configured with a self-signed certificate, False must be passed as an argument to the verify parameter. In a production environment, you will want to verify the SSL certificate.
You can find information about the ThingWorx API here.
bwalke
(To:adam11)
Thanks a LOT Adam for the detailed reply.
Can you please also provide information on how to “get” thingworx property value using python?
Thanks in advance,
Bhaskar Walke
adam11
7-Bedrock
(To:bwalke)
You're welcome : )
To retrieve a Property value, you need to modify the headers:
headers = { 'Accept': 'application/json', 'appKey': 'ed18a4a1-c6d5-46b3-ace8-b55d148e2384' }
and use the method that corresponds to a GET:
response = requests.get(url + '/Things/ExampleThing/Properties/stringProperty', headers=headers, verify=False)
Hi Adam,
I am getting SSL Error to send request from the python.
I tried to go through the link you provided, but i did not the solution. Can you give some solution?
I have tried passing the PEM file also for SSL error, but i could not able to make it. .
headers = { 'Accept': 'application/json', 'appKey': '4ddd126f-c719-431a-9b42-36b75eeebc45' }
response = requests.post(url + '/Things/TestDevice8/Properties/BatteryVoltage', headers=headers, verify="C:\All_Builds\PythonScripts\URL_Test_Copy\ems_get_connected.pem")
raise SSLError(e, request=request)
requests.exceptions.SSLError: [Errno 8] _ssl.c:504: EOF occurred in violation of protocol
