error in application log
AP_9587236
17-Peridot
I am trying to write custom service for application logs to get what services are modified in daily basis. When I updated a service "OverallMachineStatusGraph" in a Thing, I am seeing a error "Entity Not Found : [OverallMachineStatusGraph]" in application log. But the service saved successfully. Then why this error is coming? Iam using thingworx 9.2 version.
PaiChung
22-Sapphire I
(To:AP_9587236)
It would help to see your code.
Also just to make sure, the ConfigurationLog is the one that will record any modifications made in the platform.
If I updated any service in a composer, I am seeing a error "Entity Not Found : [ServiceName]" in application log. why this error is coming?
Hello @AP_9587236 ,
It would be great if you share the service code you are using and also attach the detailed logs if possible.
Bhawna
