hi,
My requirement is to Export the mashup to excel file.
1. I have performed using data export widget. I have bind the service to the data export widget(.csv).
But the problem is ,it binds only single service at a time to the widget.
2. I have multiple grids on the mashups where i have bind multiple different services.
3. how can i export the ui which is designed in thingworx mashup as it is to excel?
4. It must also export along with the colors and fonts i am using on mashup.
5. How can i export graph present on the mashup to either excel, .png or .jpeg format.
Thanks and Regards,
Sheetal
Hi @Sheetal_sable.
If you have access to Composer, you can export the data via the Import/Export option. If you need to allow data export to your users running the mashup, you could add a separate data export widget to each grid for exporting the data. This will also allow more flexibility to your users. As far as the graph is concerned, you could do a screen capture or graph it in Excel from the data that was exported.
We're not understanding your intent regarding numbers 3 and 4. Are you just looking to take a screenshot?
Regards.
--Sharon
I understand that the requirement is to see the content as seen in mashup to be exported as-is to an Excel file as a snapshot. Not sure whether there is an event or service on Mashup to take its own content-snapshot and use it for export to a file.
hi @slangley ,
Thanks for reply.
I want to export all the data present on mashup as it is to single Excel file.
Sheetal.
Hi @Sheetal_sable.
Perhaps I'm still not understanding, but it sounds like you can perform these steps outside of ThingWorx.
Regards.
--Sharon
Hi @Sheetal_sable.
Have you found answers to your question? If not, please provide further details of your use case so we can get a better understanding of what is needed.
Regards.
--Sharon
