validate a text when we enter in TextField in mashup
Pratik_Aswale
9-Granite
I want to validate a ThingName in thingworx. Like In Mashup, when I type a thing name in textbox field and enter on click button, the validator function should be check the thing which we have enter in textbox field is already available or not, if  yes the message should be Thing Created Successfully and if not then should be Thing Already Exist.
So how can we do that?
Thanks.
Hi @Pratik_Aswale
Instead of Clicked Event to show a status message. Use ServiceInvokeCompleted Event from the service to trigger/show popup message.
/VR
Instead of using validators, you could have the service where you create the thing return a status message with either success or failure message.
Hi @Pratik_Aswale
You cannot use the validator function to check whether Thing exists.
As @Rocko said you can use the service to validate it. Something like this
let result = "Thing already exist";
if(!Things[thingName])
    //Put your Script to create Thing
    result = "Thing created successfully";
/VR
Hi @Velkumar @Rocko
Thanks for the input.
After this  I m not able to see notification like Thing already exist or not in mashup.
Hi @Pratik_Aswale
Could you please post your implementation here. It will help us to understand issue better.
/VR
Hi @Velkumar
I used below createThing code:-
let thingName;
let result = "Thing already exists";
if (!Things[thingName])
let params = {
description: 'devil',
thingTemplateName: 'ttTT',
projectName: 'input',
tags: undefined
Resources["EntityServices"].CreateThing(params);
output:-
After entering thingName and click button It will showing message successfully.
I use Label widget to show message.
Can we show this message in another way like notification popup?
Thanks.
Hi @Pratik_Aswale
You can use Status Message to show results from service as a Popup
/VR
Hi @Velkumar
Here is a screenshot that what I do:-
1]        2]
output:-
In above 3 screenshot-
1st one have a binding.
2nd one have a function -In this when we don't write anything on message box and click done .Then after viewing and clicking button the message shown in screenshot 3 as a blank.
Now I m just entering Dot [  .  ]in screenshot 2  on  message box and click done.
after viewing mashup, I m able to see notification message.
How could I do  without typing anything on message box to show message?
Hi @Pratik_Aswale
/VR
