Hello All,
is there somebody who is able to explain hwo to actived an advanced search for the view part properties or also part structure app in Navigate?
I search for something like the advanced search in windchill where the user is able to use several windchill and also non standard windchill attributes to perfom a search to get the correct object result.
The standard is a bit less (number / name)
Thanks for your answers.
Hi Torsten,
Navigate search works on Name and/or Number attribute and there is no direct way to searching based on non standard Windchill attributes.
One way to achieve your requirement is by creating a Saved Search in Windchill with all the criteria and use it in Navigate. Navigate will only show the objects which meets the specified criteria. I know this is a bit tricky process as to change the criteria you have to access Windchill and modify the Saved Search.
However currently this is the only option I can think of. Will update you if there is any other alternate approach. Let me know if this helps.
Tushar Bhosale
