will 3d guided Assembly step by step instructions possible in vuforia expert capture
Take a look - "Get Started with Vuforia Expert Capture": https://www.ptc.com/en/success-paths/get-started-vuforia-expert-capture/setup/prepare-to-capture-procedures
Hi Vladimir N Thank you for your replay.
As I checked in ptc portal( Augmented Reality Work Instructions | Vuforia | PTC) and the below image where it clearly given as 3D visual guides with step-by-step instructions.
PTC show some use cases in a gallery: https://ar.gallery.video/
There you'll see AR guidance with Expert Capture and Vantage, but also 3D assembling instruction in AR, done with studio.
Hope this helps to distinguish the solutions.
