I have install thingworx studio 8.1.3.
However Thingworx Studio cannot be started.
How can I do ?
Below is detail log.
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of D:\Users\kjoono\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\PTC Inc\ThingWorx Studio.appref-ms| resulted in exception. Following failure messages were detected:
+ Activation failed.
+ Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))
ERROR DETAILS
Following errors were detected during this operation.
* [2018-01-27 오후 12:18:46] System.Deployment.Application.DeploymentException (Activation)
- Activation failed.
- Source: System.Deployment
- Stack trace:
at System.Deployment.Application.ComponentStore.ActivateApplication(DefinitionAppId appId, String activationParameter, Boolean useActivationParameter)
at System.Deployment.Application.SubscriptionStore.ActivateApplication(DefinitionAppId appId, String activationParameter, Boolean useActivationParameter)
at System.Deployment.Application.ApplicationActivator.Activate(DefinitionAppId appId, AssemblyManifest appManifest, String activationParameter, Boolean useActivationParameter)
at System.Deployment.Application.ApplicationActivator.ProcessOrFollowShortcut(String shortcutFile, String& errorPageUrl, TempFile& deployFile)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
--- Inner Exception ---
System.UnauthorizedAccessException
- Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))
- Stack trace:
at System.Deployment.Application.NativeMethods.CorLaunchApplication(UInt32 hostType, String applicationFullName, Int32 manifestPathsCount, String[] manifestPaths, Int32 activationDataCount, String[] activationData, PROCESS_INFORMATION processInformation)
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
Joon O Kim: Could you please try deleting the files under <user home>\AppData\Local\Apps\2.0\ and re-install the studio .exe file.
Do Run as Administrator when launching the Studio application.
-Durgesh
