Is there any way to copy an existing Thingworx Studio project to a new project? Or even better, create a project template from an existing Studio project?
The project folders will be located under your <Studio-Home>/ThingWorx Studio/Projects/ directory. Usually, the studio-home location will be either your <user-home> or <Documents>/
Copying projects (as a project template) can be done by duplicating the project folder (with a different name). Are you looking for a specific usecase?
No, no specific use case. That sounds simple enough. Where are the project folders saved by default?
Thank you very much!
