With the latest updated version of Thingworx studio when a new experience is created , the preview does not show anything. Similarly after publish, in Thingworx view when the Thingmark is scanned, the experience name pops up for selection but no experience is shiwn
What OS are you using? Is it possible to share the ThingMark you are scanning?
Hi Tara,
Thank for you reaching out. I realized that there was an error in the java script put in Home.js and that's why the preview was not coming.
rectified the error and it started working. Is it a normal behaviour to not show preview if there is an error in java script?
Suresh
Hi Suresh,
Glad to hear that you are now able to view your experience! I ran a few test cases locally and found that the preview will show depending on what the JS error is. For instance, I misspelled a variable and was able to view all aspects of the experience within the preview. I then misspelled an application parameter and that portion of the experience did not show within preview. Let me know if you have any additional questions.
Tara
