Pop up notification when data is changing
robins1306
6-Contributor
can someone please provide me some pointers/hints on how to achieve the following:
I get data about mistakes, which happen on a specific machine in the production through the composer to my thingworx studio. (sql- database) I can show theses mistakes by using a toggle button. Then a table with all mistakes of the last hour will be visible.
What I want to achieve now is:
A pop-up notification in the App on the device of the worker, which is always triggered, whenever a new mistake happens. So the worker can react immediately.
In my understanding, I need a pop-up which is triggered by an event. And this event is the datachange of the specific "mistake"-service.
But how do I do this? Is a js script? How am I then connecting it to this service as it should be triggered automatically?
Thanks all!
You will need to bind the service property to an application parameter. You can then utilize the $watch() function to invoke the popup when the data changes. For your popup, you can use $ionicPopup. Information on this can be found here: https://ionicframework.com/docs/v1/api/service/$ionicPopup/
