I have setup the andriod studio and followed the steps as per link below
https://library.vuforia.com/articles/Solution/Getting-Started-with-Vuforia-for-Android-Development
result directly
and imported the project updated as shown below
but never found a directory called libs in the folder structure.
Result is this,
not able to set up a sample project, I am a mechanical engineer so may not have a complete background of android studio and other stuff.
please someone guide me out to setup the sample application and make a new application in android studio and publish (Demo)
Hi @krthk86g ,
Great to hear you finished already the development for this. The project files are saved locally on your machine and are not lost when the trial expires. You will then still be able to preview your project in the Studio Preview but you will no longer be able to see it on the device with Vuforia View. Please reach out to sales regarding your use case to see how we can support you best.
Moving your Studio project to a Vuforia Engine project is not easily possible. You would have to rebuild most as it leverages a different development environment (Android Studio vs. Vuforia Studio Authoring).
Hi @krthk86g,
Is your intention to work with the Vuforia Engine? Then I recommend to check out the Engine specific community which you can find here: https://developer.vuforia.com/forum
Else, if you want to focus on creating AR Experience content and don't worry so much about the setup, then I recommend Vuforia Studio, which this is the right forum to. Most non-software developers prefer this tool to create AR Experiences as it lets them focus on the value they can create with Augmented Reality. You get started immediately here: https://trial.studio.vuforia.com/
This will provide you with an easy to navigate interface and you can publish your projects to an Android device as well. iOS and HoloLens is supported as well.
I have developed using vuforia studio which is very good and can support Creo files, illustrate assemblies but I have to make one demo use case as an independent application. because the vuforia published project may get lost when the trial period is over.
Hi @krthk86g ,
I am an independent MBD consultant and trying to demonstrate the capability of MBD using PTC products, so using the trial version of creo and vuforia but the time limit is not sufficient to create the demo use case, also lacking with windchill trail solution. Is there a possibility to provide an extended period for creo and vuforia.
