unable to communicate Thingworx studio with mqtt using thingworx foundation server
ppradhan-2
As I we are working on communication between raspberry and Thingworx using mqtt on local instance Which is working absolutely fine using 1883 server port.
But at the same time facing issue on Vuforia or ptc provided thingworx for thingworx Studio(AR), Can you please help with the same? Or can you suggest other communication method for it.
Hi pravin pradhan​,
I will check internally with R&D if the Port 1883 is open for use on the Server for ThingWorx connected to the Experience Server.
sure that will be very helpful. Thank you
Hi Ankit Gupta​ can you please help with the same
