API for Import from spreadsheet and BOM extraction code.
V_THAKARE
5-Regular Member
Question 1 : Is there any API for Import from spreadsheet.
Question 2 : Anyone know about BOM extract report code so that we can use similar to create a BOM.
avillanueva
22-Sapphire I
(To:V_THAKARE)
Import from spreadsheet is a UI action in the Folder page. There are other avenues if you want to import BOMs via spreadsheet like CSV2XML or direct Java APIs.  What are you looking to do?
I am not sure what you are asking about the second question. Can you clarify?
V_THAKARE
5-Regular Member
(To:avillanueva)
Hi @avillanueva,
I want Import from spreadsheet action in Project container.
Currently this functionality is limited to Product and Library.
V_THAKARE
5-Regular Member
(To:V_THAKARE)
Hi @avillanueva ,
If I run jcaDebug in Project container, I can see Import from spreadsheet option which is grayed out(see attached screenshot).
Question : Import from spreadsheet is grayed out in Project container, Is it due to ACL or OOTB validator?
@V_THAKARE
Generally it is based on the validator.
if the function is greyed out based on ACL it is also checked by validator and the validator checks the ACLs.
PetrH
