Add “View” and “Phantom Manufacturing Part” inthe list of attributes when using edit multiple parts dialog
jdelgado
The attributes “View” and “Phantom Manufacturing Part” don't appear in the list of attributes when using edit multiple parts dialog.
"Edit Attribute Value" is missing some attributes defined in the View of "Edit Multiple Parts" dialog
This idea comes from case 13366683 and SPR - 6288848
I suppose it would be quite confusing / or could have some related effectd: while editing multiple parts, your are editing the attributes relevant to the iterated object (only this iteration)
  • The view is bound to the revision, Reassign View applies on all the iterations of the revision...
  • The Phantom Manufacturing Part information concerns the Master of the Part. "Modify Common Attributes" applies for all Versions.
Best Regards,
Loic
