Two attribute depend on only one attribute like if I select part type machine then only machine attribute is visible and hide another one. I want without cascading attribute
Sounds like its getting complex now. Options to consider are soft-typing parts. Your first choice is selecting the soft-type (in place of that first attribute) then you can have specific attributes displayed. Cons are this is a Part birthing option and cannot be reversed. Other option is using Part Classification. Easier to modify later but will allow custom attribute sets based on the classification of that first choice.
Any related example?
