Custom User Picker Utility
11025060
Version: Windchill 12.1
Use Case: Created a custom user picker utility, and a global reusable attribute of String type. Then, created an IBA on Problem Report.
Description:
  1. How can I get rid of the find icon next to textbox? In my usecase, the IBA should not be editable from this VIEW mode. It should be changed only in CREATE/EDIT mode.
  2. Can I get a link of the user? rather than just the full name. (exactly like created by/modified by attribute on most objects)
avillanueva
23-Emerald I
(To:11025060)
What does it show if you use jcaDebug=true for that attribute in that view? Compare that to the create/edit wizard.  I suspect its using the wrong data utility for the view page.
HelesicPetr
(To:11025060)
Hi @11025060
In your data utility you have to add a condition if the wizard is in edit or view mode and based on that condition remove the search icon.
The Returning object should contains a list of components that are shown on the page.
PetrH
