Help me to get selected object Ids from search table to wizard table?
anabors-keating
I need to add an actions on the "search_table_actions_toolbar". User can select multiple objects from the search results page and click "MyAction" and this should open a wizard page with a table showing all the selected objects with some details. I want to know how to get all the selected objects in wizard table while building the data for that table using buildComponentData(). I searched all the methods available on ComponentConfig , ComponentParams as these are the only parameters passed on this method.
Could someone help me on this.
The key is to cast the ComponentParams parameter to com.ptc.jca.mvc.components.JcaComponentParams
Then you'll have access to more things, like the NmHelperBean :
Object buildComponentData(ComponentConfig componentConfig, ComponentParams componentParams) {
  JcaComponentParams jcaComponentParams = (JcaComponentParams)componentParams;
  NmCommandBean nmCommandBean = jcaComponentParams.getHelperBean().getNmCommandBean();
  // The selected items :
  ArrayList nmoids = nmCommandBean.getSelectedOidForPopup()
thanks a lot. this works fine
KD
(To:anabors-keating)
can you please mark the answer as correct.
It will help others to find correct answer.
Kaushik
