How can I get all WTParts in Windchill?
atemnikov
7-Bedrock
I need to get all WTParts, that contains in Windchill for one special report. How can I do it?
Thanks.
If you are looking for a report you can use report manager or directly query in database. However, if you are looking to query them from Java, you can use QuerySpec, refer to an example below:
wt.query.QuerySpec qs=new wt.query.QuerySpec(wt.part.WTPart.class);
  wt.fc.QueryResult qr = wt.fc.PersistenceHelper.manager.find(qs);
  while (qr.hasMoreElements()) {
  wt.part.WTPart object = (wt.part.WTPart) qr.nextElement();
Bhushan
asingh
(To:atemnikov)
The following example builds a query for part numbers:
QuerySpec qs = new QuerySpec();
int classIndex = qs.appendClassList(wt.part.WTPart.class, false);
ClassAttribute ca = new ClassAttribute(
wt.part.WTPartclass, wt.part.WTPart.NUMBER);
qs.appendSelect(ca, new int[] { classIndex }, false);
Note that when the WTPart class is appended to the query, the selectable
parameter is false. The full object is not returned; only the number column is
returned.
Results are still returned in the QueryResult object. Each element of the
QueryResult corresponds to a row and is an Object array (that is, Object[]).
In this example, the number column is at index 0 for each element. The actual
Java type for each result is based on the table column and the JDBC SQL-to-Java
type mapping.
Cat
(To:atemnikov)
I recommend to use Report Management utility (location: [site] > [utility] > [Report Management])
For your reference, I attached sql file (i.e., part.qml).  I hope that you could make a report for part.
Please, let me know if you have any question.
If you will use Report Manager, I suggest you to join this group Reporting and to read also this article I wrote Resource for reporting
In it you can find lots of report ready to use.
Marco
adev-2
(To:atemnikov)
Hi Adrey,
you can use the sql query to get all the parts
select distinct wtpartmaster.name, wtpartmaster.WTPARTNUMBER, wtpart.VERSIONIDA2VERSIONINFO, wtpart.ITERATIONIDA2ITERATIONINFO,
wtpart.LATESTITERATIONINFO
from wtpartmaster,wtpart
where wtpartmaster.IDA2A2 = wtpart.IDA3MASTERREFERENCE and wtpart.LATESTITERATIONINFO = 1;
KD
(To:atemnikov)
If you want you can fetch all the part using info*engine Search-Object webject as well.
Kaushik
