I trying to create a QuerySpec to retrieve highest branchIditerationInfo (using MAX function) value to get the latest most object
Ankit
You do something similar to the following:
QuerySpec subSelect = new QuerySpec();
subSelect.setAdvancedQueryEnabled(true);
ClassAttribute versionSortId = new ClassAttribute(WTPart.class, "versionInfo.identifier.versionSortId");
SQLFunction maxFunction = SQLFunction.newSQLFunction(SQLFunction.MAXIMUM, versionSortId);
subSelect.appendSelect(maxFunction, new int[]{wtPartIndex}, false);
This should get you headed in the right direction.
Hello Ankit,
Windchill help center has nice elaboration about SQLFunction here at
This contains an example of SQLFunction.MINIMUM but it will more or less identical for SQLFunction.MAXIMUM.
I hope this will help you in what you want to achieve.
Shirish
