Hello everyone.
I have the value of a variable of the WTContainerRef class.
Please tell me how to get the values of context attributes using JAVA?
A more detailed description is available at this link
import wt.enterprise.EnterpriseHelper;
import wt.iba.value.DefaultAttributeContainer;
import wt.iba.value.IBAHolder;
import wt.iba.value.IBAValueUtility;
import wt.iba.value.litevalue.AbstractValueView;
import wt.iba.value.service.IBAValueHelper;
import wt.inf.container.WTContainerRef;
import wt.rule.algorithm.RuleAlgorithm;
import wt.util.WTContext;
import wt.util.WTException;
import java.rmi.RemoteException;
import java.util.Locale;
public class CustomNumberRule implements RuleAlgorithm {
@Override
public Object calculate(Object[] args, WTContainerRef wt_container_ref) {
String iba_name = "ИНДЕКС_ТС";
String iba_value = "";
String num = "ОШИБКА ГЕНЕРАЦИИ";
try {
num = EnterpriseHelper.getNumber(args);
String name;
IBAHolder obj_iba_holder = (IBAHolder) wt_container_ref.getObject();
IBAHolder iba_holder = IBAValueHelper.service.refreshAttributeContainer(obj_iba_holder, null, WTContext.getContext().getLocale(), null);
DefaultAttributeContainer default_attribute_container = (DefaultAttributeContainer) iba_holder.getAttributeContainer();
for (AbstractValueView abstract_value_view : default_attribute_container.getAttributeValues()) {
name = abstract_value_view.getDefinition().getName();
if (iba_name.equalsIgnoreCase(name)) {
iba_value = IBAValueUtility.getLocalizedIBAValueDisplayString(abstract_value_view, Locale.getDefault());
break;
} catch (RemoteException | WTException e) {
e.printStackTrace();
return iba_value + "." + num;
@Override
try {
String name;
break;
